Today was a humbling experience. I went out to the garage to do what I thought was going to be a quickie job, drain and refill my forks with fresh oil. I figured that most likely the forks would have thick black crud, if anything in them. So I put my bike up on the center stand and drained the left fork leg. Much to my surprise what came out was fresh clean looking automatic transmission fluid, 5 ounces worth.
Then on to the right leg, and what drained out was thin and black, not ATF, 6 ounces worth. Hmmm, that's weird.
So I got everything drained, refitted the drain screws, and moved on to removing the fork caps so that I could add the new fork oil. I am using 7 ounces of 10 weight Bel Ray fork oil per leg.
HOWEVER....I could not get the fork caps loose. I had loosened the top fork clamps and sprayed WD-40 on the caps ,I had a few tools, a 17mm Allen head 1/2" drive socket and a 17mm piece of hexagonal stock that I purchased from Mikes XS that you can fit a wrench over, anyway I could not for the life of me break them loose. I finally used a big hammer and beat the crap out of it and it broke loose.
At this point I was feeling pretty good, I removed the left fork cap and then I started working the right loose with the socket wrench.
This is where things got ugly fast. I don't know what I was thinking. The bike was just on the center stand and as soon as the last threads came loose the front end collapsed with a bang the bike lurched forward and came off the center stand and the whole thing fell over on its side with a crash. I was stunned.
I struggled to get it upright and get the bike jack under it so I could get it up in the air and get my forks back together.
Afterward I was surveying the damage which fortunately was minimal, the right side front and rear turn signal have very minor scuffs and also the right side mirror has a very minor scuff.
I share this as a warning to anyone else who might be attempting this job. Don't remove the fork caps unless the bikes front wheel is elevated.
Until next time,
Cheers Bob
