Not really, it will vary depending on what bars you're using. Best to measure for your particular conditions. I find an easy way to do this is to get about a 4 foot length of common household electrical wiring (10, 12, or 14-2 or -3) and pull one of the solid copper strands out of it. Use that as a "template" to lay out how your line will run and what length it needs to be. Run it from the MC down to the caliper routed and with the bends in it that you'll need. The wire is stiff enough to hold any curves and bends you want to put in it. Mark the end (or cut the wire) for the length you need, pull it out, straighten and measure. It's not a bad idea to add an inch or two to your measurement just to be safe and not end up with a line too short. That little bit of extra can be easily absorbed up behind the headlight if need be.
Since you're going 1 piece and eliminating the junction block on the lower triple tree, I recommend fabbing up a little line guide to bolt in it's place. The two holes are already drilled and tapped there for you .....
