Agreed, Jetmechmarty, way less expensive than hanging out in a bar, and I've done my same of that when younger.
I believe the XS11 was the predecessor to the FJ1100?
I bought my Eleven Special in 2003. It had 10K miles on it. Today, it has about 110K. It’s a very durable machine. I’ve gone long and hard on it. It currently sits in the go position in my garage.Picked up a used XS11 back in the 80's that had been rode hard and put away wet. Getting it back to a reliable runner was just beyond the funds available at the time, so I sold it on after about a year. But man, when it did run, it was a rocket ship!! I'd love to run across another one.
Good thing I only rode this bike in first and second gear up to about 25 mph!!! F**cking hack job PO!!! Unbelievable.
A slight correction Bob... I suggested a general purpose grease and acetone... and Iirc that's what you used.I mixed up a little acetone and motor oil to slosh around in the tank.
I'll be curious to learn more about grease/acectone like what grease and what the mix ratio is and how much to use.
Bob, does this work as well as Evaporust? I may pick some up next time I’m south of the border.Your gas tank came out beautiful! That Evaporust is a miracle worker. When I did my XS2 tank I used this product, bought it on Amazon.
After blowing out the tank I tried a tip from @Jim , I mixed up a little acetone and motor oil to slosh around in the tank. The acetone evaporates off leaving a film of oil. Worked great!
within about 6 weeks, and the tank is currently in a heated room at about 70 degrees F, with fuel cap open. Do you think it's necessary to coat it regardless as you guys have suggested?
I was thinking, maybe you could try the body panel adhesive I was telling you about, to first “glue” the pieces together, then stitch them with your new tool. That would fill in the gaps between the pieces. The tool is intriguing. I’ve watched videos of its use before and noted when they imbedded the wire into the plastic, they would give it a slight twist before releasing the wire from the gun. I think this will help bury the wire under the plastic’s surface, adding to the strength of the repair. Regarding the adhesive, I don’t know how the hot wire would react with that material. So some experimentation would be needed. The stuff I use turns hard as a rock snd can be sanded, filed etc.Tonight I tried out the plastic "welder" I bought on Amazon for $40.00. It came in a kit with a bunch of pins you melt into the plastic and then cut off, releasing from the gun, which is more or less a soldering iron. You cut the pins flush to the plastic, effectively embedding a stitch into the plastic. These fairings have a lot of micro cracks at the mounting points and I haven't figured out yet what type of plastic I'm going to use to fill in the missing pieces, or how I'm going to cut that plastic to shape. There is an industrial plastics supplier here in Victoria so will start there for ideas.
It works quickly in a matter of seconds and you have to be cautious not to destroy the fairing part. Brutal smell though. I'm going to wear a respirator for the rest of this task. View attachment 259372View attachment 259373View attachment 259374View attachment 259375
