Absolutely, hopefully I'll make a lot of progress on it this summer.
Did some more work the last few days. Got a couple of things done that I've been putting off for a really long time.
First up, remember these?
Finally finished putting it all together, looks like it's going to work out great!
Also, finally fabbed up the mounting point on the swingarm for the shock:
The hole for the shock is sleeved as well.
Also, finally I got the steering stem and lower tree drilled, so now my front end is attached properly, now I need to get the front axle sorted and this thing will be on its own two wheels!
I got an upper triple awhile back that had the ignition loop welded back onto it. I got it cheap because of this, but I didn't want to use it anyway, so off it came. Some more shaving needed to blend it fully, but it looks about a million times better now.
I also built a stand for my bench grinder and my new bead roller. It's a touch wobbly right now, so I'm going to put some supports for the main pole. I'm really happy with it though.
Finally, not a shot you haven't seen before, but I just like this shot:
Thanks for looking.
Sky
