Was your bike running before you took it apart ? When you say "took apart " just what was taken apart (engine ?) There are a few things to look at before you start taking your carbs apart (espesially if ,like you say, carbs are not your thing.) Start with the basics , look at the plugs , dry them off and clean them (they will be wet from you spraying fuel in ),then try starting procedure. Keep in mind that your XS will not start if you try to use the throttle while starting. Use choke only . Have you done a compression test ? Did you replace any ignition parts ? Sometimes non starting can be as simple as a blown fuse, so my suggestion is to start looking at the simple things first . A dead or weak battery could also cause your bike non starting. Keep it simple, that usually works for me. Another suggestion, turn your petcocks to prime and turn it over a few times (to fill the bowls ) then turn them back to run.
