Hey Chris, Engines and heads are assembled then the holes are bored in them. this is why they number the individual components for matching.............when they bore the holes there is a slight difference between every engine may only be a mm or so..........Yes it has been done before, and in some cases, (pun), they will be so close to a match a seal can be formed...................in other cases they can't and may as well be called Triumphs..........These mismatch's don't look much but a seal wont work on these.
View attachment 105748 View attachment 105749 View attachment 105750
also note in the first pic the sealant used on the rocker cover has blobs protruding into the engine...........one of those breaks off and gets stuck in an oil gallery the engine is going to get cooked somewhere.........if it is in the oil feed to the crank it is a complete rebuild..........
On the Tach drive, i always tell people to keep the Tach........... If the Tach stops working on a ride.....stop....check to see if the cable is damaged/broken, if the cable is your probably good to carry on...........If the cable isn't broken/damaged, it means the oil pump is.......get a truck...........the Tacho give you a heads up............
