FastColt
- Messages
- 135
- Reaction score
- 1
- Points
- 16
Hey guys, just would like to say hi to everyone first of all! My name is Chris, Im 29 and im from CT. This board seems really cool and very informative. A little back ground on myself, Im very mechanically inclined, I have an Evo RS I just finished up that will hopefully go 10's this season. Ive had a turbo Hayabusa that I built myself, and Ive built 2 other street/race cars. That being said.....
I had been looking for a xs bob project half started for about a year, a few weeks ago i finally found a 72 project that had been started (very poorly I might add). Basically I picked up a rolling hard tall frame, only tacked together, and a box of parts. No sweat right? WRONG!
As I started delving more into the engine, discovered that engine and frame are stamped with the same number (good), I believe the top end of this motor has been replaced(judging by the different colors). I also found that in the box of parts I had been given a 80's reg/rec combo instead of the seperate units. Now, after searching around a little more online tonight I think I have a newer style coil as well. Lastly I opened up the points covers and found I have no freaking points!!! Kinda pissed but oh well, i need to fix this situation. Here are a few pictures i took tonight and hopefully you guys will be able to help me out.
First of all, what side does the points go on? All the pictures ive seen so far have had them on the left side.There is nothing for the points to be attached to on the left side, on the right side the cam appears to be threaded.
engine right side
engine left side
Second, what the hell is this spare wire for that some idiot cut? All the wires have a home in the rec clip, this random one has no where to go.
Third, coil. Will this work? Or is it the wrong one.
Fourth, do the head/cylinders look to be not from the stock engine?
Any help you guys can lend would be awesome. Thanks so much!
engine right side
engine left side
