I had an interesting time getting mine apart and thought this might help others.
In my post above you will notice the carb on the right, actually left carb when mounted on the bike, the top of the bowl bolt is
rusty. Well 3 of the 4 on that side were all the same and 2 on the other carb as well. The 2 on the left carb not so bad and I got them out fairly easy.
The head on that front one was already buggered from someone trying to remove it.
Knowing that to remove these the normal way would probably have stripped the thin material of the carb body I did this;
Cut the heads off by drilling or with a dremel cut off wheel, I used both.
Gently pull off the bowl from the newly created studs, what's left when the head is removed. Don't want to bend or break any bowl flanges.
Grip what's left with vise grips and turn clockwise as far as you can.
Then cut the rusty section from the end of the bolt.
Turn counter clockwise and remove.
Result, no damage to the carb threads.
Wish I was so lucky. Worked for 2 bolts but that one on the front, had to drill out the newly created stud and by luck got it really close to center. Keep stepping up the drill sizes and with some more dremel work with a fine bit got the remainder out.
JUST SHIT HOUSE LUCK.
BUT BOY AM I HAPPY.
Notice how clean the bowl is. Can't believe the condition of these.
