wwitten
First off thanks to the members on this board for all their great information. Without many of you my TX650 never would have gotten so far. So far I have always been able to find a solution to the sometimes never ending issues that I have faced getting this bike back to at least a rideable condition.
Now after many months and many hours and quite a few dollars, she is running and doesn't look so bad for a 40 year old. In my test rides I discovered as have many difficulty finding neutral once the engine is hot. If fact really can't shift up at all if engine running and bike is stopped. No problem if engine isn't running, but once she gets up in temp if engine running....not able to shift up to neutral. Naturally followed all the advice here, new cable, cleaned and lubed adjuster. multiple trial adjustments all with no success.
Therefore went to the next step, and removed right hand cover to check shifter adjustment. That's where I really f'd up. Tried to remove the clutch unit without the "special tool" and broke a tang off of the exterior of the clutch basket.
In hindsight see that Mikes has the "special tool" and will order along with other pieces and parts, to eventually get her back on the road, but will need a new/used basket. Other than ebay...any other sources.
Once again thanks
Bill
Once again thanks
Bill
