Rez Fink
Ok my clutch was slipping a few months back and so I ordered new clutch springs and drained the oil. Well I barely got to my project a couple weeks ago. When I removed the plates I noticed a thin curly wire sticking out inside the basket. I pulled it..and it grew and grew... After research I found out it was the clutch boss clip/ring. (I HAVE AN 83 XS650SK) So I ordered that part and installed it with the new clutch springs...
So here's my problem...
After I installed I did a quick pull on the clutch lever...it looked like the plates/basket moved out. So I put the right cover back on. I put oil back in it and fired it up, pulled in the clutch and dropped it in first. After a short lurch forward it stalled. I tried dropping into 1-5 gears and moved the bike back and forward WITH THE CLUTCH LEVER PULLED IN and it wont go into 'neutral'. (while not running)
my guesses:
- i put the clutch plates back in but NOT in the right sequence? or facing the right way?(is there a right way?)
- the clutch plates dried out and somehow this is effecting it?
- somehow by putting in the new clutch boss ring/clip that's affecting it?
- the new clutch springs are too much pressure for the worn clutch plates.(yes they were SLIGHTLY below the recommended thickness)
ANYWAYS.... let your knowledge flow and hopefully someone can give me the right answer.
my guesses:
