The "rebuild" kits are pretty much just a waste of money. Yes, you need to go through your carbs and clean them out but that usually doesn't require replacing things. You don't just change stuff out, you only do that if it's worn out.
yeah, i was too lazy to make the drive. i'm in south austin so its a bit of trek. I'll look out for it next time I go there for cables and connectors. Its a great place.
I cleaned the switch, it did have some ohms of resistance, but now none. Got it started again last night. This morning, no spark again. i did test the new coil. suppose to be 4.5 ohms but its reading 6.1. i'm wondering if that's the issue. Does anybody know if there is an operating range?
... it RPM's like crazy if I rev it ... don't know what the nipples/stems coming out of the carburetor mounts going to the engine are for but they are spurting fire!
