maia 8cars
Hi and thanks for your advice on my starter problems, took it apart and cleaned it, everything good. I cannot get my oil delivery pipe to stop leaking. It leaks right at the banjo bolt connection, not where it enters the crankcase. seems like not the best system... I have actually lapped the ball and socket bits together to try to get them to mate better with no luck. I put the banjo bolt in the vise and assembled the unit and plugged the two top tubes and blew through the bottom and it leaks air. the threads are good . seems to me strange there is no gasket in there, you know... hot oil under pressure. Common problem? Thanks in advance.
