Well, just to add to the confusion, I replaced my ball and spring with just a threaded stud that eliminates the pressure relief function. I didn't want junk bypassing the filter on startup.
The bypass is there supposedly to prevent engine damage due to oil starvation in the event that the screen gets plugged up with some junk from a self destructing engine. The problem with that idea is that the bypass would open and let the junk bypass the filter in order to save the engine? I don't think so.
Also, the junk would have to get past the sump filter, so that could only happen if the sump filter had a hole in it, which it often does, but I think that the hole is made by the increased flow of thick cold oil and that the flow increases when the bypass valve opens, so keeping it closed will help prevent a hole in the sump screen, except that not having a bypass valve means that you should have an oil pressure gage so you do not exceed 14 PSI when the oil is cold. I did install an oil pressure gage when I eliminated the bypass valve and my sump screen lasted 13 years and 60,000 miles so I guess it works.
