I seem to have a oil leak that no matter what I do will not stop
I think maybe ouil is coming out the bottom hole of this line Circled Can this be so????
The thing you circled is a blind passage. It should be sealed. If air can get through it, then you need to re-seal the hole at the bottom with JB-Weld.
i have had two different side covers on this bike & had cover of at least five times & have used gasket sealer on gasket but still it leaks
I will seal the hole fit a new gasket with sealer as well & see what happens
Yup - often people forget those copper washers, and from the closeup pic of your oil drip, I don't see one under that socket cap bolt. Given it's right at the bottom and right beside your oil leak... hope it's as simple as that.
