My brother gave me this bike after he quit working on it and let it sit for about 10 years. I presume the parts you are referencing are some of the parts he either lost or neglected to give me. Nonethless I just researched the clutch rod on mikes xs and I'm seeing two varieties of the clutch rod, a long rod and a short rod. Is there an advantage to having one of these rods over the other?It could be a couple different places but I don't see the clutch pushrod, just took out for pic? Also don't see any hardware on the starter gear cover.
Hi Chris,My brother gave me this bike after he quit working on it and let it sit for about 10 years. I presume the parts you are referencing are some of the parts he either lost or neglected to give me. Nonethless I just researched the clutch rod on mikes xs and I'm seeing two varieties of the clutch rod, a long rod and a short rod. Is there an advantage to having one of these rods over the other?
Chris
One final question. As I just purchased the long pushrod from mikes xs, how would I go about installing it? I assume I would have to remove the ball bearing.You can get them at a hardware store, I can't remember the size off the top of my head. M6x1.25 maybe????
No excuse for this? I hope my posts aren't offending you pal. In my opinion I'd rather get the advice of others with experience with these bikes rather than spending my time finding and translating a shop manual. The whole point of having a forum focused on the XS650 is to connect with others, ask questions, and share your knowledge. Nonetheless thanks for the help.The starter cover bolts are M6 x 25mm long. Many times, you can determine a bolt or screw length by looking at the part number. The middle set of numbers often tells you what it is .....
http://www.boats.net/parts/search/Yamaha/Motorcycle/1977/XS650D/STARTING MOTOR UNIT XS650D - E - E006501- - F/parts.html
In this case, the "06025" tells you this is an M6 bolt that is 25mm long.
You don't have a shop manual do you. Most of the questions you're asking would be easily answered by looking in one. There are free copies on-line so there's really no excuse for this.
Chris,No excuse for this? I hope my posts aren't offending you pal. In my opinion I'd rather get the advice of others with experience with these bikes rather than spending my time finding and translating a shop manual. The whole point of having a forum focused on the XS650 is to connect with others, ask questions, and share your knowledge. Nonetheless thanks for the help.
This is the current state of the bike. Keep in mind, the paint isn't in perfect condition. As a temporary solution to my paint problems I chose to plasti-dip the tank while I save up to have it professionally painted. I still have to go about cleaning the entire bike, as there is still some dust and oil hanging around.Chris,
You are deserving of praise for working on this neglected xs650.
Do continue to ask any questions.
I hope that the repair work goes well.
If you haven't already, how about sharing a pic of the whole bike?
Hey Chris, you've a great a great start to a good runner !View attachment 99750 View attachment 99751 View attachment 99752
