The kick starter moves about 1/8 of the arc but then it's locked solid. P O said had the RH cover off twice..... What am I going to find? The chain and front sprocket were off, rear axle was still tight with cotter pin in place. (loose parts neatly in a baggie) Bike had charging system problems, that is related, for bonus points tell me why. Bike had drop cafe bars the original "special" clutch cable routing would have done a Boa constrictor proud. Super man probably couldn't have worked the lever. I put the chain and sprocket back on, routed the cable so it will work. It shifts through all the gears. No battery or key, I haven't tried the e start Before I open it, what is "wrong" under that RH cover?
