Had a short work day. By choice or by chance?
So I was able to get back into the shop.
Tried swapping condenser leads, no change, so I guess that tells me this new Daiichi condenser is OK. Wires and caps were new last summer so they should be OK.
Found a couple of issues.
Checked dwell again and it had increased by a degree or so on the left side to 21.5* - 21.8*. 5twins says should be 22* - 24.5* on the 4cyl setting.
I imagine this increased gap won't help with early points opening, adding to the problem.
But, paint me green and call me a pickle!
2M, you never cease to amaze me sir! You nailed it………..‘Again’.
Had a look at the screws I had put in, they looked to be the same length as the original stripped screws that I took out.
Seemed to measure the same length but it's hard to measure thread length on those little beggars and the heads were different so couldn’t measure overall length.
Then went digging in my hardware boxes and found ‘someone’
must have added new points plate screws to a parts order one day.
They were definitely shorter than the originals and than my replacements.
Swapped them in and I'm no longer at the extreme limit of adjustment. Things have settled down, no more bouncing around. So those screws must have been too long to seat the plate properly. Huh.
Thanks 2M, I owe ya another one!
Now, ya want to put your diagnostics hat on again?
When tuning noticed a noise that I have not heard before. After revving it up, when it drops back to idle I have been noticing a rapid click click or click click click noise. I know that’s not very helpful.
This is a new one. Definitely on the right side. I first wondered if it was oil pump or tach drive but I think it’s back in the transmission.
When I put a mechanic's stethoscope on the neutral detent plunger I pick it up….
and more so here at this case bolt
It's running great, shifts fine, (a little clunk noise going 1st to 2nd), neutral occasionally an issue after a few miles when warmed up (need to fine tune clutch adjustment a bit) but a little crack of the throttle solves neutral problem.
Starter gear fix was done last fall and did not hear this noise back then.
Edit: tried the Kickstarter today for the first time, works fine.
Any ideas on this one guys? Am I worrying about nothing, tipping it over to pull the right case again to look for something amiss, or digging deeper?
