Well, here we are……. Again!
I’m sure hoping this ain’t her favorite position!
Got everything apart today. All washers were properly located, unfortunately. I was hoping I had messed up and put two, 2mm’s together in error. Would have been too easy eh?
No broken cush springs.
I 'think' I may know what the problem is but I have no clue as to how to verify or correct it.
Sure wish you had that Time Machine up and running 2M. I'm going back to 1990 here and I have trouble remembering yesterday.
I think I had mentioned in the past that when I got this bike in 1990 the PO had dropped it 3 or 4 times and figured he'd better quit while he was still alive.
This last time resulted in a missing shift lever. Missing because the shift shaft was sheared off flush with the left case. That would have taken some skill, as there were crash bars on the bike. Also a broken clutch cable and a few other things that I just can't recall.
I needed a Ministry of Transport Safety Inspection done so that I could get it licensed. So I took it to a local mechanic to have him do the safety and replace the broken shift shaft while it was there.
When I picked the bike up, the clutch wouldn't fully disengage. I can recall an interesting trip home that day.
Once again the details totally escape me as to how, but somehow I figured out the shift shaft wasn't seated properly. Maybe I checked my manuals. maybe I heard a noise, maybe I felt something, but I figured I may as well give it a go. I pulled the right case cover and saw this.
Somehow back then I must have popped the shift shaft and stuff back into place (or there abouts) and it was fine for 18 years of riding.
Now we fast forward to 2018.
Here's what the inside of the right case looks like now.
You can see the rub marks have gotten bigger so the clutch basket is making contact again.
Here is a pic again from last November showing those earlier rub marks.
And one from today showing how they've increased.....
Also can see in this pic where it'd been rubbing.
I don't know about all this stuff but I wonder if the shift shaft somehow again isn't fully seated therefore the clutch basket is sitting a bit proud and is making contact with the cover? Hence my tick, click.
I don't know how much clearance there should be here but I got a 20 thou feeler to fit. Held the basket tight. If I went to .021” I could feel the basket move out a bit.
Maybe I should put things together with the nut to absolutely confirm the gap here?
Does this make sense guys?
Obviously, it's rubbing on the case again as the rub marks have gotten worse.
Are there any tests or measurements that I can take to ascertain if this is in fact the issue. How can I tell if the shift shaft is properly seated?
Secondly, how do I fix it if it isn't?
Thirdly, if this isn't it, what the heck should I be looking for?
My apologies for running you guys around in circles, but all this historical stuff just came back to me as I got in there once again.
Hopefully this will once again be true.
Thanks again guys!
