Ok guys got the BBQ built the fire pit built also and with those out of the way being ahead of schedule I went to work on the front end today.
I was able to mount the front tire, install the rotor, put Hugh;s solid risers on and changed the forks out. I know have a ROLLER!!!!!
The Hugh's kit with it's O-ring fit is a really nice kit. I had to sand down the riser clamp stem bolts that go through his kit as everything was to tight with old gunk and even the factory paint that was on the stems. So I ran Scotch bright on the shouldered stems and even had to file a bit an the end of the shouldered area as it had been kind of mushroomed from all the flexing of the original rubber mounting. Cleaned up the holes the bushings go in lightly oiled and bolted it all up nice improvement!
I also ran Scotch bright all of the holes in the triple clamps and lightly oiled them to slide those fine looking forks in without scratching them up, I pulled them up about 85mm for now to drop the front end a bit, and because I know my Dad would had done this we did with many times and know all the hows and whys of it.
Went to mount the caliper and it needs rebuilding and is frozen up so I had to remove the pads to get it on. That phillips screw that holds them in is ....well..... turned to shit as it was so rusted and froze up so bad it took me a bit to get the SOB out. But here is cool part for me I went over to that old Craftsman tool box of my Dad's and in there is the Craftsman screw and nut extractor kit I had seen him use many times. Selected the correct size a slight tap with a ball peen hammer to get it started gave her a twist with the ratchet and it came right out, the old guy is still with me out there!
So I took the roller out for a roll so it could be seen from the sky above and it's first rays of sun light it seen for quite some time. It starting to take shape in the stance and looks department. Looks like she will fit in with the trio I had spoke about in the preamble of the thread. The tires I have now look small on the rear but really look pretty good on the front.
