Ok so I have ordered a PMA from Hugh its on the way...I have pamco already installed also...but as for the new reg/rec it has positive to go to battery and ground I was gonna put it at ground on frame where battery ground goes. Should I put any kind of fuse on that positive from battery to reg/rec and if so what size? Also I think as far as the pics on hughs blog for PMA install the reg/rec has a plug harness on it already....what if I found a matching harness to plug into it and on the other end of wires I put connections for the battery +/-....is that doing to much..lol .should I just run + to battery and ground to frame ground. Keep it simple
