Received the flywheels back from balancing...
XS Charge (from a complete kit)
Mike's XS (purchased separately)
The numbers look like this:
- Stock rotor (electro-magnet); out 0.08 oz-in.
- PMA rotor #1 (XS Charge); out 0.18 oz-in and corrected to 0.03 oz-in.
- PMA rotor #2 (Mike's XS); out 0.24 oz-in and corrected to 0.02 oz-in.
I had told the balancing shop that max RPM would be 8000, and they replied that the "balance tolerance" should be around 0.03 oz-in. at that speed, but that was considered a pretty tight tolerance.
They also said that the runout didn't appear excessive to them, so I am going to test fit the flywheels again, with & without the woodruff key.
For anyone considering getting their flywheel (stock or otherwise) balanced, Jim VerCande at Detroit Balancing Services is easy to work with, and has tooling ready to accept XS650 flywheels.
You can contact Jim at:
572 S. Mansfield
Ypsilanti,Michigan, USA, 48197
TEL: 734-480-2337
FAX: 734-480-2354
website :
detroitbalancing.com
email :
jim@detroitbalancing.com
