Machi
Setting up a Hugh's PMA kit on a '75 rebuild. Going to be running without starter or battery, with stock dual points. Have a TCBros capacitor. Simplified wiring, with only headlight, taillight, brake light, ignition switch, headlight switch.
With the right side already buttoned down - What's the safest way to hold the crankshaft steady while tightening down the PMA flywheel?
Is the position of the flywheel relative to the crank NOT important, as long as we get it at TDC before marking it?
Thanks - I'm sure I'll have more questions (like setting up the old dual coils!)
