Lluber
Noob
Time to clean up the rats nest of wiring.. I'm running with a headlight tail light and horn. no blinkers or tag light. I also don't use my electric starter. Any one running a ballistic type battery or something similar?
I replaced my rotor about 9 months ago (custom rewind) have a extra set of brushes incase mine wear out im getting correct readings from my current battery when the bikes running 13volts. I noticed that the headlight does go a little dim when I'm at a idle and when I get on the gas the headlight brightens up.. I would rather not spend the money on a PMA kit and just slim down the stock wiring harness and fab up a smaller battery box and cut away the unneeded wires to clean up the area behind the carbs.
looking for pro's and con's of running a cell battery.
Thanks everyone
Thanks everyone
