I am having some issues getting my 77 xs650 motor to start. I purchased this motor without hearing it run. The motor sounds like it is trying to start. It back fires pretty loud after about 5 kicks. I have installed a new pamco ignition, a new battery, and new spark plugs. The motor has air, spark, and fuel. I have installed the duel output coil from mikes Part #17-6822 and spark plug 1 k ohm cap Part #23-3116. I believe the pamco is installed correctly and the wiring is correct, I have checked it three times. The battery has a charge during the trials of getting the motor to start. I know the carbs have nothing to do with this issue because I put my friends carbs on from his bike that runs great.
The clutch side of the motor cover has not been on during the trials. Could this be an issue. Could timing be the issue. If so any pointers on how how to correctly adjust the timing?
Any help would be greatly appreciated.
Thanks
Thanks
