poorman9
I have a 81 650H running a boyer blue box (Micro-Digital Ignition System - kit 00103), I bought this bike with the blue box, so I'm back tracking a bit here.
The terminal between my spark plug wire and the Gill ignition coil has broken off (see photo below). Where can i order new copper terminals for this? I took the coil into three different shops and they all just could understand why the coil didn't have a screw on connection, apparently this type of connection uncommon?
Also, apparently I'm running 5K ohm spark plug caps with this. Can somebody explain why?
And actually I want some new wires too. Can someone suggest the wires I should be using with this system? High Tension Wires? Performance Silicone Wires? 7mm, 8mm?
Basically I need help setting up the correct cap, wire and coil end or a link to where I can buy it with out assembly required.
Thanks.
Thanks.
