TeeCat
One-Mik Wonder
Guys -
As some of you know, I will be installing a Mike's rec/reg in my '73. It comes with instructions, which address the basics, but I have a couple more questions at the moment. I'll likely do this work this coming weekend.
Supplied are plastic terminal connector blocks for both the reg and rec side, since the new solid state unit will plug into the stock harness. Both male and female plugs are supplied, but do I HAVE to use the new ones on the harness side if the new ones mate up to the old ones, or is it just advisable? I'd like to do as little soldering as possible, though my temptation is to do everything all new.
Also, when assembling the blocks to the wires, I:
- crimp the four little tabs on the metal male/female connector to each wire;
- solder over the crimped connections; and
- insert the completed wire/metal connector into its hole in the plastic terminal plug.
Is that right? I just want to make sure I have secure connections in the right places - I'll have to pay attention to that - and I'm a bit concerned about not being able to get them out if I screw up.
Also, the instructions say (on the regulator side):
The latter is my preference.
Now, the instructions also recommend mounting the new unit into the old mechanical reg location. But does it have to be installed right on metal, or rubber... not sure if that matters at all, both in terms of vibration isolation and proper grounding... though it will already be grounded with the black wire.
Thank you.
TC
For an improved secondary ground, run a black wire from the base of the new unit and splice it into the battery negative lead, or run the wire to the black wire in the connector block.
Thank you.
TC
