Jtporter9
JT
So I recently bought a 1980xs650g, i love the thing, I've been replacing a lot of things on the bike, mostly the basics, new carbs(broke old ones), oil change/filter, petcock fixed up, etc. I've been having some bad wiring problems with fuses burning out, namely the fuse that leads to the regulator rectifier. I haven't figured that all out, but I figured out i can start my bike up if I leave that fuse out. So in my enthusiasm I did so tonight, and she fired up great! I decided to take her around the block and back, things felt great then about half way around the block I killed the engine, and when I went to start her up if seemed like my battery was dead, I figured so since it wasn't being charged by the generator. But I got back to the grace to leave that the battery was fine, I got her running again, but when I give her gas, she quits instantly. The left exhaust was warm, but the right exhaust was not, on checking the spark plugs I found that the left one was a little white, and the right one was wet form either gas or oil, (most likely gas) and some what black/ or dirty. Im thinking it's one of 3 things.
1:I need new jets(most likely bitter I assume.)
2: she's misfiring
3: there is some sort of short in my coil/ coil line to the right side preventing a spark.
I'm lost here guys. If you've got any thoughts let me know! Thanks!
Ps: if you guys know anything on my wiring issue explained above, let me know! Thanks!
2: she's misfiring
