You mean the start button no longer works?
Your handlebar is probably no longer grounded. See if there is continuity between the bar and your frame. If not, run a wire from the frame to your handlebar to ground it. Start switch should now work.
im running kick only. i took the switch off and straight wired my headlight so that both high and low beams would be on all the time. i don't have blinkers so i decided to do away with the switch. also removed all gauges and indicators. also running pamco.
