Whats the best way to remove the studs from the cases? I am looking at one of the 1/2" socket drive cam type ones, I rented one to pull all the studs from an engine years ago but IIRC I nearly destroyed it getting cylinder studs out. There are also sets that apparently lock on the threads and can be used to remove or install studs, don't know if that type would be up to pulling case studs though. It's going to be a mock up empty shell and everything is out. just going to leave in a couple of studs to hold the case halves together and the cylinder on. Humor me, I am doing it because I can..
Oh, off hand anyone know how to release the shift forks from the shift shaft? I have the cotter pins out, now what?
