How can something be the "real deal" clear in a spray can? The reason I say this is not the price or that it is actually available . . its because 2 part, cured, paints has a short pot life. They were harden in the paint gun after a couple hours. They chemically cure, not air dry. So how is it they can be put in a spray can? Well there are some high tech spray cans out there that allow for mix as it exits the can. I can only assume this is one of those. So, if it works and the quality is decent . . cool. But understand, once you activate it, that can cannot be stored, you must use it all. Still . . . I'd almost want to try it myself to see
Still a consideration is the chemicals in the hardener. Its isos, which I suspect it must be, you need to be protected.
Now for others . . if you find painting very rewarding, getting a small gun and compressor will allow you to paint a lot more than a spray can will allow. If funds are tight, maybe a good x-mas present to ask someone for
Once you have a gun and learn how to use it, you can do so much more.
