DeftQuiver
Hey Everyone,
I'm currently in the process of fixing up a 1980 XS650G, and all has been going pretty well up to this little gremlin.
Background:
About 4 weeks ago I adjusted the cam chain tensioner to spec, cleaned the carbs, checked the float height, installed new throttle shaft seals, new carb boots, and set my valve clearances. Then about a week ago, I threw on some drag bars, and swapped out the brake lines, master cylinder, and clutch cable, leaving the throttle cable stock.
After all that, it was running pretty strong for about a week (maybe a little rich, a faint squeaking noise that I'm trying to pinpoint, and some top end noise that I'm pretty sure is normal). So just last night, I was riding and the bike kept holding Revs at around 3-4k RPM's and would stay up there for about 3-5 seconds.
I went home and sprayed some carb cleaner at my carbs and boots, and didn't find any leaks. I also checked the cable and lever operation, and it appeared that the cable and the throttle lever were snapping right back into position. I then put it on the center stand to see if maybe the clutch was not disengaging, but that wasn't the case either. It had fouled a set of plugs before I made the adjustments listed above, so I've been pretty diligent about checking them, and they've been a bit carbony, but when I pulled them last night they still had carbon on one side, but the other side was bone white. I'll post pictures when I get home.
Any other thoughts on what this might be? I always thought that holding revs was a lean condition, which may be the case, but my plugs have been pretty carbony for the past week.
Thanks for any insight,
Deft
Background:
Deft
