Hotlap72d
Right cylinder blows cold at low rams and hot when revved please help!!!
Hey guys I have a 81 xs with bone stock everything motor and ignition wise. Here's my problem when I start my bike the right side pipe blows cold/misfires at low rpms but when I rev the bike up you can feel the exhaust warm up but then right back to cold once the rev is over. I have checked the cam chain, checked valves and everything is good there but the intake valve on the left side had to be backed off a fair amount more then all the other valves but the left side is firing. I checked spark and have good spark, swapped wires, swapped plugs and it still is dead on the right side no matter what plug or wire is there. One thing I have found is that my right carb isn't really pulling vacuum, haven't put a gauge on it yet but it is def lower then the left side. When I unplug the right side vacuum plug the bike continues to run but when I unplug the left side the bike shuts off almost instantly. Also I have gone through and cleaned both carbs and checked both diaphragms. The bike does have mikes xs air pods and straight pipes so I know I'm going to have to tune/rejet the carbs but I'm just trying to get it running. I also have pulled compression tests on both cylinders and they are at 120psi. Any help is appreciated.
