btxs650
I've got an 83 Heritage Special that starts right up, seems to run fine with no lack of power in any part of acceleration. No popping or crackling or rough idle, but it has always seemed like the right cylinder doesn't fire as smoothly and consistently as the left. It's only noticeable while idling at about 1200. Put your hand up to the left header and there is steady flow. Put your hand on the right side and it misses a lot.
It doesn't appear to be lean issue because both plugs are identical with a nice light tan color even after putting over 1,000 miles on it since I upgraded to pods, larger jets, and open headers.
The intake boots do look a little too cracked so I sprayed them while running to see if it would die, and it didn't even sputter.
I've got the BS34s with pods and increased mains (142.5) and pilot jets (either a 30 or 45, I can't remember which) with open headers.
The bike has less than 4,000 miles on it, so I've not messed with valves or timing yet.
