bluexs650
While purchasing Mikes XS parts to upgrade my 73 TX650 to 6 drive plates/ 7 friction plates, I bought part #39-6578, Ring- Clutch Boss (retaining wire). See on this page: http://www.mikesxs.net/products-22.html#products
The description: "Spring Steel retaining wire for Inner Clutch Hub (Clutch Boss). This wire holds the first metal clutch plate (special type) in place on the inner clutch hub and is easily damaged if removed from its installed position."
I am puzzled as to what this is for. What is a "special type" first metal clutch plate? From what I can see, all the steel plates are the same. Is this part a tool that is to be removed before final assembly or is it a part that remains on the cycle? Thanks
