Micksin
Steep Learning Curve
This is not a 'help me trouble-shoot my charging system' post.... I'm hoping for some guidance on what to do now that I have established the problem.
I have just bought an '83 XS-K Heritage Special. I confirmed the model here (http://www.xs650.com/forum/showthread.php?t=42) by using the engine number. It was recently imported from the states – I bought it from a guy who did the import to Australia. Unfortunately it looks as though my new 32 year old bike (with only 5500miles) has a charging problem.
Thanks to the awesome information in this forum I have tackled the troubleshooting, learnt shed loads and established the following:
· No charge above battery voltage getting to the battery terminals. I learnt this the hard way...breaking down a long way from home...in the rain.
· No magnetism at the alternator when ignition switched on.
· The reg/reg connector had some 'chalky' connections (red and whites). I replaced the plug and all the connections here.
· Battery charge is getting to the positive brush. Only slightly below battery voltage (Initially, I took a DC volt reading from the positive brush and the negative brush and got 4.69 DC volts. But when I took the reading from the positive brush and another ground I get near battery voltage – I assume that I must have taken the first reading incorrectly?)
· The Brushes are fine. Plenty of room left.
· Rotor has reading of 1.0 ohm between the slip rings and 44.5 ohms when grounded on the rotor nut. It's toast.
· I also traced voltage through the wiring system and checked the resistance of the 3 white wires going to the reg/rec. all good.
So, I have read a lot on here about rewinding rotors, buying new ones and upgrading to PMA. I'm trying to understand which is the best option:
1) Get a rewound, used or new rotor? I'm concerned that after I do this I might find that my reg/rec is also be knackered and then have to spend more coin to sort that out. I did the reg/rec bypass test where I jumped the green wire to ground to test the output back to the battery – it failed to increase. But during the 'green wire' test I also tested the voltage at the positive and negative brush. Prior to the jump I was getting a reading of 4.69 DCV...with the jump I got 8.69 DCV. Does this prove anything about the reg/rec? Is it likely to be knackered as well?
2) Upgrade to a PMA like the 200watt kit on Mike's XS? It looks relatively easy to install....but, given the bike I have (83 XS-K), do I need to upgrade to a cam timed ignition system as well? If so, why? I'm quite confused on this.
3) Go the Banshee flywheel option? Do I need to upgrade the ignition system for this to work? If so, why?
Or is there an option 4) ?
I am not looking for high output...I'm happy with having the bike run as it is (or was). I don't have a garage to work on the bike and am very green when it comes to bike mechanics..But am keen to learn. And, I'm on a budget. It took a long time to save for this bike and I'm not keen on forking out too much more...but I do want a reliable bike.
Thanks in advance for your help...
