Hi there,
I rescued my '76 447 XS from a 20 years sleep.
Went thru the carbs (cleaned, new kit, new floats).
Cleaned the tank, new oil and cleaned filters.
New breakers as well.
The problem is that she runs on the left cylinder. I think I got the right cylinder running at a time (right exhaust became hot) but didn't happened since.
The right cylinder gets fuel: spark plug is wet
The right cylinder gets spark too
Swapped the spark plugs, wires and coils. Doesn't change anything.
Swapped the wires that come from the condenser, same problem.
Breaker points aren't throwing sparks or flames while it's running so I guess the condenser is still good.
Carbs are set to the factory setting, 1 turn 3/4 if I remember well.
Any idea ? I'm stuck
Regards,
Thib
Regards,
Thib
