rut31
Those are just counterbore bungs I got from bung king. That's actually where I got the idea to try this, seeing their Harley motor mount kit. I made it specifically for my build though. I have the stock top motor mount cut out and have a Frisco tank. Polishing, I experimented with a bunch of stuff. It depends if the piece has deep scratches that you want to get out or casting marks. If so, I just use my mini DA sander and work from low to high grit and throw it on my 1hp bench buffer and use the compounds I need depending on the material.Just mainly interested in what you did on the bolt sleeves. I'm guessing you just turned them down some to clearance the bolt head?
Also, any tips on polishing, what steps do you take??
