This is what Im trying to figure out, the bike starts GREAT, the bike runs GREAT, I got a rewound rotor from custom rewind, the safety relay starter works when the bike is running, so not enough power 4.5 volts is getting to the relay to trip it to keep the starter from working, the headlight wiring is all messed up, I still have to work on that.
I guess I trying to figure out whats wrong here, bad rotor, bad safety relay, bad alternator, bad regulator/rectifier, all the connections look clean, if not how do you get into the plug and clean those things....what do you use????
This is getting very frustrating, I want to be sure this rotor is in good working order so I can send them my core to get my core deposit. I thought once the new rotor was installed it would put out enough volts 4.5 through the yellow wire to trip the safety relay so the starter button would not engage the starter when running, then I could work on the headlight, gonna need that to work, for obvious reasons.
The only things that aren't working properly on this bike is the starter working while the motor is running and the headlight that won't work until the safety relay is figured out, once these two two things are figured I should be golden.....we'll see.
