xs650dude63
OK, i tested the stator 3 white wires per leos instructions, I touched the testers probes together and got 1.5 OHMs, I touched white wire 1 and 2 and got 02.0 OHMs, I then touched 1 and 3 white wires and got 02.0 OHMs then I touched 2 and 3 white wires and got 02.0 OHMs.
When I did this I would touch one of the wires with the red probe and the other with the black, the numbers jumped around a bit then settled on 0.20.
Then I went to test the whites to ground, I put the meter on 20K, then I touched the first white wire with the red probe, then touched the black probe to the frame of the motorcycle, I got the same reading on each wire 004.
I will perform Brassnecks tests tomorrow and get back with my results.
Just a thought, when I bought this motorcycle, it kept blowing the main fuse, I removed the stator cover and found a little screw that came loose and was lodged between the brush area and the stator cover, it was arcing for quite a while, is it possible this shorted out my stator? Thanks!
