Chito
I've been searching around and it doesn't seem like anyone is having this problem.
So I have an 81 xs650 Special. I took it to a shop to have a new tire a Shinko 777 130/90 - 16 and got it on. At the same time I had a new chain. The shop calls me and said they had a problem, but it is sorted out.
I get the bike back and the tire rubs on the swing arm on both sides. (Rubs may be too strong, but you can't see light between the tire and the swingarm when it is sitting still. I think you can hear it when you push it) The chain is in the first 1/3 of the adjustment settings. They also shimmed the sprocket out and I'm now running a 520 dirtbike chain so the chain wouldn't hit the tire.
I have a 73 tx750 swing arm on there... so I swapped it out for the 81 special swingarm... same clearance problem, so I put the tx750 swing arm back.
It's not an option to take it back to the shop and work it through them.
I was told adding a link would make the chain too long.
It looks awesome... I just can't figure out what is going on with this. I've been told that the shape of the tire just doesn't work with the bike. Anyone else running a 777? Any ideas?
