halliday77
Hi guys,
I've been reading the forums intently trying to work out what might be wrong with my bike, but my patience is wearing thin and despite picking up some new skills, I'm getting a bit over it.
Here's the skinny:
- '81 Special, almost all original, brilliant condition.
- Bought it in Victoria two weeks ago, started and ran well.
- Put it on a transport truck to NSW. When they unloaded it, it started and ran well.
- Five minutes after that, I gave the throttle a decent squeeze and the bike cut out.
- After that, turning the key to 'on' only produced lights intermittently for about 5 minutes, then not at all.
- Figured it was the battery, bought a new one. No change.
- Closer inspection revealed a blown main fuse.
- Replacement fuses would blow instantly when hooked up to the battery.
- Read forums for two days straight, bought a multimeter.
- Spent another day working out how to use it.
- Do some tests as per the manual and isolate the problem (I think) down to regulator.
- Yank it out, test it as per manual and the resistance readings fail the manual test. Order new one. (Should be here in a few days).
Here's where I lost the plot.
- Hook the bike back up without the regulator in. As far as I understand, I should be able to get the bike to start, it just won't charge the battery while it's running. I can't do this (though I wonder if the new battery needs a charge).
- Further investigation shows that when I'm all hooked up with no regulator, I'm instantly blowing a signal fuse. No power to the headlights and console lights and (possibly unrelated) the middle console bulb is blown. Not sure if that was like that before.
So by my reading and reckoning, it sounds like I have a short to ground. My problem is I'm at a loss to work out where, and I'm not entirely sure where to start and how to test the wiring and isolate the problem part/wire.
I have all the right tools, plenty of time and determination, and there's still a BIT of patience left.
If any of you could help me out by putting me on the right track as to where I should start, and how exactly I go about testing the circuits, I'd really appreciate it. I love figuring this stuff out and it's so much more satisfying if I can nail it on my own. Just need a bit of guidance.
Thanks in advance guys!
Hope to hear from you.
Here's the skinny:
