How thick is the magnet? I used a 0.5mm thick magnet because it will experience less force when the rotor turns. When you glue it on you need to make sure the surface is thoroughly clean. I also had a good coating of glue around the edges. A Neodtmium magnet is much stronger than the older types, so even if it looses some strenght a engine temperature it should still work the ignition.
Recently, apologies to the author, an ignition issue was solved just by shining the surface of the old magnet back to looking new. You try this.
