webbrs
I have stupidly left my spark plug wire off after checking the plugs, twice. ironically both sides once.
I only turned it over a couple of times before I realized it but I believe it is a high output coil like MikesXS pt#17-6803, as it has the two leads to the plugs facing the front of the motorcycle. Now I am having real bad acceleration problems. I have jetting issues but this is getting progressively worse and I am thinking bad jetting doesn't change it just stays the same bad?
So, I have a dyna coil 3.0 ohm dual fire on my HD I am not using. Will this coil work on these motorcycles? I noticed that one on MikesXS that is 3.3 and is similar to mine
http://www.ebay.com/itm/Dyna-3-Ohm-...Parts_Accessories&hash=item27e67e2df4&vxp=mtr
Some tech on this would be great if I can get it to run, hobble to work tonight and work on it or my other car this weekend.
thanks
thanks
