This all started back in October when I pulled the tank, airboxes, carbs, and seat for the first time. The electrics took on visual prominence and I knew an overhaul was coming down the pike. I had all sorts of shoddy diy connections, dead ends, etc., etc. A rat's nest. An overhaul to come, but for the time being I would get the stock system working and see what needs to be fixed or replaced.
But an overhaul had been on my mind.
While I thoroughly enjoy the particulars of commuting every day on a classic motorcycle, we must admit there are some factors we would wish improved. Safety being one of them, if not the mother of all.
In my opinion, one of the best ways to increase my chances of getting home each night is to make myself more visible. I know I can't close the gap completely, and I'll still ride as if I'm invisible, but I want to give other drivers the best chance of seeing me. My Ferrari yellow helmet isn't a fashion statement. When the time comes, my Aerostitch will have the Hi-Vis trim.
I wish my bike was brighter on the road. Running lights would be nice.
I had a run of 1157 incandescent taillights blowing like crazy. With no redundancy through running lights, I had no lights on my tail at all. As a daily commuter, I was troubleshooting this amongst 15 mile commutes on a 60hr week. I tried a vibration-resistant LED 1157, but it was confusing the brakelight checker. Some dampening bubble wrap behind the reflector keeps the incandescents going.
I live in Phoenix, and I know y'all don't believe us when we say it rains, it does. A few times a year. Not enough for me to have a second mode of transportation. Not enough for drivers to be practiced in careful, smooth, predictable driving in inclement weather. In a 35mph section, some will be doing 10, others 40. It's a mad house out there, and visibility in our monsoons drops to practically nothing. Sometimes all I want is some hazards. But those will have to let turn signals work because those are important, too.
While it is true that the stock system supports the usual load very well and relays aren't necessary, SPDT relays will allow me to get my intended functionality and control out of the stock 1156 stalks and sockets.
I am building a custom harness, but much of the other wiring will be stock. For example the small harnesses from the headlight bucket to the various handlebar and center clusters. The alternator, SSR, stater relay. New connectors, but OEM style.
Some original wires will be repurposed. For example, when you switch on a turn signal, there is flashed power from a brown/white sent down either the dark green or chocolate wires to the respective lights. Fair enough. There is also a red/yellow that is made to ground when in either L or R settings. This usually goes to the flasher cancelling unit. I will use it to switch the hazards relay, temporarily suspending it as either turn signal runs. That's the theory, at least.
The rear stalks will have connectors added at the stalk, allowing for signal relocation or built-in lights in case of luggage bags.
Thanks for the encouragement. I'm pretty confident I'll come back out on the other side, but let's just say I'm watching this thread as well.
