EvenmoreXS
1981 XS650
You can lose a fair amount of oil over the mileage you're talking about from it seeping out or getting slung out where the stick goes in, if you're missing a good seal there. Cork is best and it's what came on it originally.
Another possibility is a loose head bolts. Oil can leak internally from a passage into a combustion chamber. Re-torque the head bolts, paying careful attention to what you're doing.
Also, an apparently competent rebuilder on here says his rebuilds use a qt of oil every 1000 miles. So if you were to rebuild you might not gain anything.
I can order a new dip shit seal. Stick, I mean stick !
Head bolts are unlikely, but I will check that last. I should see some smoke if its burning consistantly in combustion chamber. Very very little to no smoke now, and only on start up. When I put the head back on I checked the torque several times over 24 hours before adding oil and firing her up. Im certain the torque job was good. That was then, this is now.
Next oil change, I'll keep track of the amount of oil added and the rate of loss.
I did notice that I have 1 drip of oil under my bike a few mins ago... First drip Ive seen in 2 weeks parked in the same exact two spaces. Looks like it could be a slow seeping leak in the starter area. I do have the starter block off kit from mikes. Push rod seal is good. Could the starter be leaking a bit and would the block off help seal it. Im going to do some research into this tonight.
Thanks everyone
