mattofferdahl9
- Messages
- 9
- Reaction score
- 0
- Points
- 1
Hey guys first time poster!
I have a 1980 xs650G I bought that had a bad cylinder. I removed the engine, replaced the bad piston and then painted the engine, and reinstalled it. Now I have no spark. I had spark prior to taking the bike apart. I really didn't tamper with the wiring other than disconnecting what was necessary in order to remove the engine. What I've tested so far..
I have power at the red wire on the ignition harness.
I have power at the coil
I have power at the tci
I thought maybe the paint was making for poor grounds, so I removed some of the mounting bolts and used a round file on the inside of the mounts, and removed the paint from the outside edges. I also used new brp7eix plugs and cut the wires back a hair and reinstalled them. I still am without spark. I even ground the plug to the negative on the battery and had nothing.. My headlight doesn't work and my brake/oil light is on when the key is on, if that's normal? I unplugged my rear blinkers since I don't intend to run them, and I don't know if that has something to do with it? Also I may have had the wires backwards on the starter solenoid.
Any advice on where to go next? Also does the key only have one two settings, on and off? Thanks!
