Sump Oil Filter
BowlingSS
XS650 Guru
XS650.com Supporter
Lawrenceville, GA
If I am installing a Heiden oil filter kit do I still need a Sump Oil Filter? Mine is torn and needs replacing but was wondering if I still need it.
Thanks Guys.
Which Heiden oil filter kit are you fitting? I think he has one that fits on the r/h side of the engine, and another that replaces the sump filter.
Heiden has at least 2 oil filter setups. One that uses a small Honda filter, in a special housing bolted where the stock filter is. And the other is an adapter, hoses, and remote canister filter, normally fitted fwd of the engine. And also 2 versions of the sump strainer. One is a repop of the stock strainer, the other one is a cylindrical strainer that is supposed to be better.
