tach sleeve screw
randeman
Cypress,Texas
Building a 72 XS 2. I have misplaced the little 6 mm ( I think) screw that is screwed in from outside of the casing to hold the tach sleeve in place. I believe that it was turned down on the end to fit into the corresponding hole in the sleeve but don't remember.
Can anyone tell me or have a drawing of it?
Parts file..........
Was just working on that side case and oil pump today. Im making a tach bypass adapter for the hole so I had mine out. I measured it for you also. Over all the bolt is .680.
From the bottom of the head of the bolt to where the threads start it is .520 to the tip,
The machined tip if it is .148 across the diameter of it.
The tip is .17 tall.
Hope this helps
