So I finished my bike and ran into a problem. Its a 1981 xs650 special with a XS750 tank. The tank is coated with caswell. The tank has two petcocks. Instead of the stock, I decided to use pingel petcocks with adaptor plates. The painter got my tins back to me and I proceeded to install petcocks and ultimately I rode the bike for a few days. Unfortunately after two days I noticed one of the petcocks was leaking around where the adapter plate attached to tank itself. Even worse, the gas proceeded to track between the paint and the metal tank so I got an area about 3/8" beyond the adapter plate where the paint bubbled up. The painter has graciously agreed to fix it or even repaint the whole tank if needed. The problem arose from improper cleaning and/or masking around the plate mount area.
Anyways, I have been messing around with the plates, trying to get a good seal on them to the tank. I tried permatrex permashield which is supposed to be gas proof but that leaked immediately. I then sanded down the mounting area on tank as flat as possible and reinstalled the plates using the rubber gaskets that it came with again. This time is seems to be holding, but I am really nervous it will ruin the paint if it starts leaking again.
In retrospect, I should have welded plates onto tank, but I cannot do that now.
I was thinking of roughing up the surfaces of the plate and the tank and using some JB weld to permanently affix the plate to the tank. After that, I was thinking of recoating the entire tank inside with another thin later of caswell epoxy sealer to seal any small channels between plate/ tank/ JB weld. Do you think this is a bad idea? This would permanently affix that plate and I shouldn't have to ever worry about it again, maybe? The plate has a standard 3/8 NPT threaded hole for pingel petcock and I would leave those threads intact so I could still remove and rebuild the actual petcock if needed.
Thanks for advice
On attached pic below, you can see where the paint came off around plate.
Thanks for advice
