XS650s are new to me, I just got my new bike running with a carb, tank and petcock cleaning. I tried to set dynamic timing. It looked like it the points needed full advance to just barely get to the F mark while I was timing originally. Then something funny happened mid-stream, it got really retarded somehow as I was playing around with the points plate and cam chain tensioner. Suddenly the most advance I could get is to the red lines in this image-
Other questions- the lines I highlighted yellow- are those like a range for idle timing? there's 5 lines on there and I only expect to see the 3, I am guessing the full length lines I highlighted green.
Anyways I am clearly way off and if I take my points plate slightly off full advance the bike won't run any longer. Note there's no air filter currently, and I don't believe the bike was ever jetted for the degrading Uni filters that it came with. waiting to order new pods and jets ...Uni or K&N?
So i'd have to expect something like a chain jumping a tooth? I did let the tensioner out until I could just hear slap then tighten it back up while running. I wasn't really familiar with that process, so I was experimenting
But I found this article http://www.650motorcycles.com/CamTiming.html
Removing the advance unit, I found that the pin points straight up on what I understand to be TDC, the far right green mark.
Any ideas what could have caused this?
